I've static timed my bike a few times now, and I can't seem to get it right. Stock ignition, stock charging system, puts out 14 volts at idle, and sometimes will fire on the first kick.
When I attached the timing light to the right side wire (top points) it doesn't work. It's intermittent. Attach it to the left side wire and it works as normal.
I tried testing the coils, but couldn't get anywhere near the correct ohms on either coil (bounced around alot).
Is this a pretty good determination that I've got a bad coil? Or are the points not correctly set? I figured if I can set one good then the other should be close after multiple tries.
Posted via Mobile
Posted via Mobile
