motorshag
I know this has been talked about before, but wanted to show something I've discovered while chasing the bunny. I bought this bike from a guy that said the Carburetors needed to be cleaned. So, I decided I would just go through the bike like I always do. I did clean the Carbs and noted that was not the problem... I noticed a few things right off the start that seemed weird to me. The cam chain tensioner was very very tight...(Adjusted all the way in) So I adjusted it back to where it seemed normal. The valves were so tight that I couldn't even move them (perhaps never adjusted?). So I adjusted them the way the should be adjusted (to spec). Then I get to the timing, just can't get it to time right. One of my discoveries was the PO was using a single coil Accel Harley Super Coil. I did not think that was correct, so I put some standard coils on it. Ones I knew worked. I could get the points to gap on the right side correctly but never the left side. Also the timing plate was way off, I had to move it so far counter clockwise and I couldn't ever tell with my meter when the points were closing or opening because ignition mark on the rotor never line up midway between the two marks on the alternator housing. The ignition mark would be almost 15 degrees out or whack. So I started doing some research here, there and everywhere and I discovered through my reading that maybe the timing chain is old (30 thousand miles on the clock) and my be its very worn? I pulled the motor and pulled the cam cover off. Then I saw what was wrong. See the pics...
It looks like one of two things happened when the PO did a rebuild or "something" the chain was removed or replaced. Not sure if it's new or not, but I do know it's got new link
1) The Cam timing mark was not set at 12 o clock while the motor was at TDC?
2) The PO adjusted the chain tensioner out so far that the chain jumped a tooth?
Additionally, I guess my question is this. While doing this process should I pulled the head too? I don't want to, but I guess I should check the pistons to see if they have been hitting the valves?
No I didn't checked the compression. The compression checker was sitting there, I just got excited and then....Sorry I forgot...I guess I could still check it, I've not pulled the head yet.
Just thought this was interesting. Feel free to share your opinions, and/or theories as to why this could have happened.
