Hope this is on subject. If I remove my cylinder for leaking base gasket repair will I need to hone the cylinder upon reassembly?
jefft
sivarTi, get the complete engine gasket set. That comes with all the o-rings and valve guide seals, too. It's probably a good idea to replace the valve guide seals because of their age, cam chain too because of the work involved tearing one of these down. If you keep the bike for a while, you will end up needing and using most all those gaskets in the kit.
Ultra copper form a gasket is a mirical in a tube5twins and/or retired: What about using spray on copper coat on the entire head gasket? Thoughts? Are there any particular brands of gaskets that seem to be best?
