madass140
Hello gentlemen and ladies. advice needed. Assembled engine from parts. all good except changing
down usually from 3rd wont select 2nd . I replaced the following to no avail, Complete clutch,shift shaft, everything on the end of the shift drum. I've adjusted the eccentric spring stop bolt below so that the
ratchet arm which rotates the shift drum is correct. Yesterday went for a ride, when cold changing
gears was reasonably ok, but after 30 mins riding in hot weather I could not change gear at all. its as if
the shift drum was frozen. Let it cool down for 7 hrs and was good to go again.
I was thinking that through heat maybe the shift drum had lost any end float it had and locked up.
I havent checked that yet but if it looks like there is no end float then a sharp tap inwards or outwards
on the shift drum may help. Any clues?
