xsPete
G'day,
Another one of my many questions on wiring this thing from scratch.
HEADLIGHT -I'm using a K&S handlebar switch (15-0055)
It has
Headlight main
Low Beam
Hi Beam as separate wires
I wired main through to power (fuseblock)
I wired low to low on the headlight
I wired hi to hi on the headlight
All this works great
TAIL LIGHT - Posh with 3 wires, red which I assume is brake, black/white which I asume is tail light, black which I assume is earth.
I hooked it up to Headlight main which I didn't mind at all as it comes on when the ignition is open, except lo & hi don't change
I hooked it up to headlight low beam it's on with lo but goes out when I switch to hi, the headlight still works though.
BRAKE LIGHT
Hooked up as continuity switch setup
If I hook the brake up without the headlight lo circuit it works.
As soon as I hook in the tail light it will work on lo only and the brake light doesn't work at all.
I'm stumped on this.
Any help appreciated.
Pete
It has
Headlight main
Low Beam
BRAKE LIGHT
Pete
