Jpkole513
Nvr give up Nvr surrender
So after months of searching I finally found a straight frame with a clean title. It's an early frame 1972 with nothing but kickstand bolted on and I just got it home today. Upon inspection next to my 1978 I'm noticing things I didn't know differed between the two generations, I got the motor mounts with the new frame but after measuring the neck I can tell the steering stem is too long to swap front ends from the 78 to the 72, I did some reading and that should be a somewhat easy fix with the shorter stem and a press. I then measured the swing arm and that didn't seem right either (I can't get in the 78 to well as the bike is still together) does anyone know if Infact the swing arms were different or would anyone be able to tell me other problems I may run into doing this swap, maybe some tips?
