No, you'd have to lean it over much more than just on the side stand. You'd have to lay it over practically on it's side. If the oil is fresh, you could just drain it into a clean container and put it back in.
Agreed - if you are unsure about the oil and its service history, you are best to just change it. XS650's will live a long time - but dirty oil hurts them quickly.
Having said that - leaning the bike over is a great way to service the clutch side of the engine. I use a car jackstand with an old towel wadded up on top of the stand-pad. Place the stand under one of the exhaust header studs on the LEFT hand side of the head and
gently lay the bike down onto it. The bike will be at an ideal height and angle for you to remove the RH engine case cover while sitting on a low stool or even on your bum on the floor. Be sure to keep track of the many (I think either nine or 11) socket head (i.e. Allen) cap screws and note which ones have the little copper crush washers on them. If you work carefully, you can often re-use the gasket on the RH engine case-cover.
If you do need to remove the clutch - the best way is to use an impact driver on the six
JIS clutch screws. JIS means
Japan Industrial Standard and while they may look like a Phillips screw, they are not - and the geometry is just different enough that a Phillips driver can strip a JIS screw head.
JIS drivers are readily available on the web at low cost - and the best brand is Vessel, most of which come with a fetching light green-blue handle. Here is a photo of a complete set - and they are well worth the price if you work on
ANYthing built in Japan.
Another excellent (and less expensive source of JIS drivers is GoFastInnovations of London, Ontario Canada. I do not have any connection with these folks, but their products are great and they ship fast. Here is a linky:
https://www.gofastinnovations.com/
The XS650 clutch screws will be pretty tight and so I recommend using an impact driver to get them off quickly and without damage. The one you need to do the clutch is the
Vessel IMPACTA #3 model which is on the far right in the photo above (the one with the
silver handle). To use any impact driver properly:
- Put the driver bit into the screw head and lean on it to push it firmly into the screw;
- Rotate the driver in the "loosening" direction - CCW - to preload it;
- Hit the butt-end of the driver a good smart blow with a steel hammer.
There is no-need to go neanderthal with the hammer or use a big sledge - just one good swat with a carpenter's hammer should do it. In my experience, this will loosen the clutch screws instantly and without damage.
In fact, I found that three of the six screws on my 1981 XS650SH were badly damaged when I got in there - and they actually looked much better
AFTER I used the
Vessel Impacta #3 driver on them.
Pete
