So I'm about to attempt to make my triple trees and I just want to be sure that I have this right. Can anyone here verify this distance for me? I got 1.378"
I'm having too many net crashes to do the searches, but found handy info using the google search function on 'triple tree offset'. Also, I seem to recall measurements posted in member 'teebs' thread, solving his bent triple tree issue...
I set my 75 upper tree in my copier. Copied it off on paper. Drew some lines and from the center line of the tubes back to the centerline of the stem I get about 1 13/16 inches, 1.93 or 50 mm.
One thing, If you widen the trees you will need a longer axle and extra spacers so the wheel will fit.
Right Leo, I know this is gonna fall under the "building a death trap" but my goal is to use a rear drum rim up front so I'm planing on using the rear axle. I've seen 650 with 16" front wheels so I know it can be done its just a matter of figuring it out.
