XStretchified650
Back in the 650 Saddle
Lately I've been able to spend some time working on the engine. And....I have some questions.
I pulled off the head and the cylinders. The cam looks like new with no wear marks on the lobes and the rockers are the same, nice and shiny. The front cam chain guide looks like new. I'm tempted to reuse it instead of using the one that I bought from MikesXS last year.
It sounds like a lot of people reuse the one that is on the tensioner side but end up replacing the front guide because it is frequently pretty beat up. Should I reuse my front guide? If the OEM ones were made better than Mikes what would I be gaining by switching it out? Beside 'new glue' that was made in China.
The wear strip that is on the tensioner side has two shallow grooves in the plastic. See the first photo... Is this one fine for reuse?
The pistons had a nice snug fit in the cylinders before I disassembled it. The cylinder walls look very clean to me and everything feels smooth. Up at the very rim of the cylinder there is a uniform build up of varnish. Where I was able to wipe it away the metal is consistent with the cylinder wall. I think that once I get the varnish off I will not find a ridge where the rings stop their stroke. What is the best solvent to dissolve the varnish? Carb cleaner did not help.
Here are some photos of the cylinders. Would you hone these or leave them alone? I will be using new ring sets when I reassemble.
