Not to criticise your build, because I do like the work on the tank and those bars and other stuff, but that rear shock set-up has been bothering me. Maybe some one can fill me in on how the shocks are supposed to work when the distance from the pivot on the swing arm to the lower shock mount is lots longer than the distance to the upper shock mount. Doesn't the sweep of movement to collapse the shock and provide suspension need to be in the same arc? It would seem that all you are doing is side loading the shocks and decreasing the collapability of the shock as the angle increases.
