Tiesco
I challenge you to a guitar battle
I play Weissenborn acoustic Guitar - lap steel. That count?
I have a banjo and fiddle but always come back to the guitar. Been meaning to say something to TZ after seeing all his guitars.
From what I understand the fork springs were weak to begin with, and with age are probably shot. Plus you never know what a PO might have done. My bike is pretty much all original, but when I went to rebuildOn my 77; From the bottom of the tree clamp to the top of the dust cover is 5 inches with a 3/4 tank of gas and the bike on the side stand.
When I raise the bike off the side stand, the forks compress under the bikes weight 5/8th inch.
( I'm starting to see Metric smoke out the ears...) When I mount and put my weight on the bike the forks compress another 3/4 inch. If I brake normally, the forks compress as much as 2 1/2 inches more. I think the springs are too soft? I may need to put a 3/4 inch spacer under the cap bolt.
My forks two winters ago, I found my spring setup is definitely not stock. Best to buy some quality springs. Make sure to replace your seals if you’re going to go to the trouble. Just replacing my seals and adding the proper amount of new fluid made a world of difference for me and eliminated my brake dive.
LOLTZ, I bet your right. I have original shocks. I also tore them down, cleaned and reassembled them. I'm running 10 weight fork oil. I may go back to a heavier weight. ( The 77 fork tubes are different from any others) For my type of riding they suit me fine. I just think they need to be a little stiffer. If I were to put a "lunch bag" under the light, my samich would get smurched in a panic stop.
Interesting, for a couple XS's and years I did exactly as you describe. And read occasionally of adjusting the cam chain with the engine idling.. na, I got it right? Well, one day I too popped the acorn cap off and "tweaked" the adjustment back and forth a little. Damn, Even Better !I adjusted my timing chain yesterday to see if it helped the "ticking" I was hearing. Haven't started it to see,
you could "park" an XS650 on the front bumper apron. no need for a carrier.Been a great day. Spotted a canary yellow Lincoln on my way home with my daughter this morning. Had to show her up close.
I’ve had three of these cars, two white and the most recent one baby blue; with a white coach top and turbine alloys just like this one. It was my daily driver when I met her mother. We had some wild times in that car. Always made me think of Billy Joels’ “It’s still rocknroll to me”. “Nowadays you can’t get too sentimental- your best bet’s a true baby blue Continental” One of my favorite cars I’ve had. Took the bike out for a lil spin to get warmed up, down to the parts store for some oil and fuel line, then Changed the oil and the plugs, and retarded the timing a bit since I adjusted the cam chain a few days ago. When she’s cool I’ll check the valves. I have new pegs on order from amazon, same style as the old ones I used to have on it, only chrome instead of unfinished aluminum. Mirrors are supposed to be here by Friday. Should have everything installed and tuned by May 1st, just in time for some real weather. Took a pic in the O Reilly parking lot cause it was just lookin so good.
Happy Zombie Jesus day
Thanks gggGary. There a few minor misquotes but otherwise happy with this.Not mine...JP1's bike
https://email.partzilla.com/public/...-_lElsx7I5RVyoVqqWuRUxQg-WG0Ppr0V-mdi0bPDgJj0
Thought this is cool
