Sheesh it looks like it cooked. How old are those rockers ?The cam don't look to hot.
You have a oiling problem. Notice how much heat was concentrated at the pads. Lack of hard surfacing won't do that. Lack of oil will.The rockers are as old as the rebuild which is about 250-300 miles. The old rockers had the same wear pattern but they weren't burnt and the cam never was scored like that. Geez
Oil could be. I've never seen a set of Mikes lifters. Could be they just case hardened the business end (colored) and that's what were looking at? I don't know.You have a oiling problem. Notice how much heat was concentrated at the pads. Lack of hard surfacing won't do that. Lack of oil will.
I've never seen Mikes rockers either. But I've seen enough engine and other failures to see lack of lubrication problems going on here.I've never seen a set of Mikes lifters. Could be they just case hardened the business end (colored) and that's what were looking at?
dang.. well I'd agree you found it alreadyI am missing item #4... the piece that holds in the rotor. So the oil pump wasn't doing anything at all..
That would do it.I think I found a big fuck up from the PO. I took off the oil and pump and....
I am missing item #4... the piece that holds in the rotor. So the oil pump wasn't doing anything at all...
But the strange thing is, whenever I took off tge covers to adjust the valves there was always oil there. It didn't seem like there was a lack of oil either
I hope I don't ever hear that. Yep, I feel for ya, Tiesco.That would do it.
Should have had a "dry" sound at top when running. If you've never heard a motor run dry you may not have noticed. Next time you will.
It is a tough motor. Roller bearings don't need a lot of oil. Plus he probable wasn't running it all that hard. The assembly lube I use lasts for a long time on bearings and pistons.Oil pump? Wondering how it ran 250 to 300 miles like that? I tnink there are spirt holes for the ConRods. All it was getting was splash? Motor must be tougher in places than I thought it was.
Trans only needs oil in the cases. Doesn't need pump.It shifts find and drives fine and runs fine.
It was trying to tell you it had a problem.The only thing that was weird was the valves ticking like hell after adjusting them more and more frequently.
I have no idea how it ran that long. The bike never sounded like it was hurting or anything.. It shifts find and drives fine and runs fine. It sounded completely normal.. The only thing that was weird was the valves ticking like hell after adjusting them more and more frequently.
I'm sure the rest of the motor like the crank snd the transmission is probably ok. I hope anyway. They are at least partially submerged in oil.
And somehow. Just enough oil was getting to the top to make me believe that there is not an oiling problem. I dont know how that possible if the rotor isn't spinning.
