AussieHard
AussieHardTail
For the tech experts out there.
I have ordered the Gary Poh wide tyre kit today, and am going to order a weld on Wide-Hard Tail from Elswick.
Now I know that they take a 5.5" tyre or 180/200.
For Mr Luck's version you need all these extras:
Has anyone done a Elswick wide-tail????
Located a few cheap 21" wheels on bay for the front, lets hope I get lucky.
HTML:
http://www.elswickcycles.com/hardtail_xs650_wide.html
- What size is that 16" or 18" (Elswick mentions 18 but others have 16) and does the hub on a 6" match a 5.5" if so can I put a 6" in?
- There seems to be more used 6"x18" around.
- All places seem to refer to using Harley rims, is there other options???
- *16" REAR WHEEL,40 SPOKE, CHROMED. WITH 3/4" SEALED BEARING 199.99
- *DRILLED REAR BRAKE DISC, ZINC PLATED 42.99
- *REAR ROTOR MOUNTING HARDWARE 13.99
- *REAR AXLE KIT FOR 3/4" BEARINGS & AXLE ADJUSTERS 107.98
- *CUSTOM 34 TOOTH REAR SPROCKET FOR HD WHEELS & YAMAHA ENGINE, BY KOSMAN 65.99
- *16" TIRE, HDS "Super Eagle" BLACKWALL 129.99
- *16" INNER TUBE 23.99
- *16" RIM STRIP 1.49
- Do I need any of this for the Elswick version??
- Will the stock brakes need to be replaced?
- What else do I need to find out?
