Dennis
when you readjusted the worm gear did you first loosen the cable at the hand lever?
The cable I just replaced works normally until I tighten down the side cover bolts, so I think I can eliminate the cable as being the cause. But I appreciate what you're saying.Well it seems youve eliminated the easy fixes, the only way forward is eiter try another cable or dig deeper.
I'm in Maryland, just north of DC, but the bike's not really mobile due to the clutch lever issue.Where do you live, maybe some kind soul on this board lives nearby and can help with some work space!
That side cover hasn't been off since I've owned the bike.If you're sure you have all the Allen screws out then the gasket is the only thing left holding it on. If it's never been off since '72 then chances are it's stuck on there pretty good.
The brake pedal's no problem, but, other than unscrewing the knurled nut at the end of the cable) what's involved in removing the tach cable? There's a bolt just below the cable. Does removing this bolt free the tach cable:You'll need to remove the tach cable and the brake pedal to pull the cover off.
Lovely.The kick start shaft should remain in the engine - if you hold it in with your thumb as you work the cover off. If you don't, it will pull off with the cover. You don't want that. The return spring will unhook and you'll lose the tension on it. You'll need to re-install following instructions in the shop manual. Like I said, just make sure it doesn't come out with the cover and you can avoid all that.
Will-do. Thanks again!Get a rubber mallet and start tapping around the cover to break the gasket free. It may take some pretty good raps.
The only bolts left in the side cover are the two in the oil filter cover and the bolt below the tach:No real trick to get it off. Double check you got all the bolts (known as socket head cap screws) out, I've been guilty myself of leaving one in and not being able to get the cover off A few taps with a soft hammer all the way around the case should free it up.
