Chances are if you are careful you will be able to reuse the case gasket.
So I don't need to apply any gasket seal to the gasket when refitting the side cover??
But before you bump (or pry if inclined) check for another bolt in the case you only have 9 on the ground. Also pay attention to the ones with copper washers(4) they go below the oil level which will be the 3 in a line across the bottom and the last one going above the line of the 3 at the front
In your pic of the tach cable you only have to unscrew the cap. The bolt secures the the gear drive in the hole.
Odd? Except for the oil filter cover, those were all the bolts in the side cover. I checked it a number of times. And there were only two with washers and those very definitely came outta the far right-hand side, not the bottom. Still, what you said about those bolts being below the oil level makes sense. Maybe I'll see about getting some copper washers from a hardware store and put them on the bottom bolts.
I would suggest getting the exhaust out of the way and brake pedal.
As you've probably found out the clamp of the kick start and brake pedal needs to be spread alittle for easy removal. When I was younger I would have grabbed any ole straight screw driver and hammered it in. I've found a stiff bladed putty knife is a better way. It spreads all the way across but you aren't fighting the "wedge" of a screwdriver.
I've included a pic of the putty knife in the kick lever.
Thanks for the pics, but the kick-start pedal came off (without any problem after I removed the locking bolt) yesterday. The brake pedal shouldn't be a problem either, but those header pipes are a pain-in-the-neck to r&r. Ugh!
The hammered impact driver. Goggle hand held impact driver. Sears has a couple of nice models. The problem with an HF impact is the machining is very poor and the operation is rough.
I got the hammered impact driver at Sears yesterday, but what is an "HF impact"?? Is that another name for the hammered impact driver or something else?
You say that the clutch gets hard as you are doing up the cover, this worries me. Check what Gary said. If thats good loosen the cable from the lever fully and back the adjuster right off on the case (keep a little tension on the cable with your hand to stop it falling off the actuator). Then fit the cover fully with all the bolts (watch out for your altenator wires) then softly softly adjust up at the side cover till its right then finaly adjust any slack at the lever. I know we've been through this before, but there is something up!
Considering how much more of the bike I've gotta disassemble before I even reach the clutch, I think I'm gonna try starting from scratch with another new clutch cable.
Let me know if this sounds correct:
1) I'll remove the current new cable.
2) Adjust the screw adjuster on the hand-lever all the way in (i.e., in the position that releases all tension on the cable (when fitted)).
3) With the cable
off the bike and the hand-lever adjustment all the way in, I'll loosen the lock nut on the worm gear, turn the center screw in (gently) 'til it bottoms. Then, back it out 1/4 turn and tighten the lock nut.
4) Install new clutch cable, reinstall side cover (with all side cover screws tightened) and check hand-lever tension, which should be loose since the adjuster's still all the way in (no tension).
5) Adjust the hand-lever tensioner until I have the spec'd free-play in the hand-lever and check the hand-lever operation.
PB Blaster is NOT oil in an aerosol can. It's a penetrant lubricant which when applied to the clutch case gasket--the gasket will eventually absorb it and make it easier to take off.
I think weekendrider's got it right. From your description, PB Blaster sounds like WD40, the original penetrating oil. But thanks for the tip just the same.
