They are sealed but depending on the year, they will have metal or rubber seals. If they're rubber, you can pop the seal off and add grease. Don't fill them all the way, it will only ooze out once they heat up, fill them about half way. If you replace them, get the 2RS (two rubber seals) type, not the "Z" or "ZZ" kind. Those are metal shields and you can't remove them to add grease.
Oh, and alfred, even though you are a king of asses and the hats they may wear, you have good tastes in hammers. I've used an Estwing in one form or another for over 30 years at work. They are the best.
