patentgeek
Clutch questions directed to the resurrection of a crusty 1970 XS1/XS650. . . .
The (6) fiber clutch plates measure 3.5mm thick and the (5) metal plates measure 1.56mm thick, which seems to be in spec.
On the downside, the left engine cover has a long crack at the rear on the top side and the clutch cable hole has a big chip . Additionally, the clutch actuation mechanism is very rusty, and the plastic worm gear is cracked. So some new parts are in order.
Will a later left engine cover and actuation mechanism fit? And if so, which years would provide the best clutch actuation?
I'll be fitting a TX500 rear hub to my bike, which features a rubber cush drive. Would there be additional benefit to using a 1980 or later inner clutch hub that features a dampener?
The clutch spring retainer Phillips heads are showing some wear and tear. Is there an upgrade to a socket head type setup?
Any other recommendations? For example, newer design clutch plates, springs, etc.
This will mostly be my girlfriend's bike with a very mellow engine build, so ease of clutch pull and actuation are the most important factors.
