Pulled my forks off a few weeks ago, filled with chem dip, waited till today.
. Took off the chrome scraper cover, cut off the rubber scraper, and dug out the seals. Rusty mess. The all balls seals are about 1/2 mm too big, but since they are rubber covered i just roloced the excess off. Use my bench vice To force them in. Other than the seals being a rusty mess, it all looked in great shape. I put in the spec'k 10/30 wt,
And upped the amount a few cc's
I also took out the loose ball races in the head stock, and put in the tapered bearing kit. Fits better in the early bikes than the later years.
I also cleaned up the business side of the front drum, and put on new shoes.
Putting it back together in with the headlight ears, those chrome washers, the turn signals, then holding it all together while reaching for the wrench to tighten the pinch bolt was a pain,mbut i got it done.
Observation-- only one pinch bolt on the lower fork per leg?
I also only have one spanner nut on the stem. Is that rite? Its the one you need a spanner wrench to tighen, its the one with the sleeve that goes up into the top tree, and i cant tighten the yoke pinch bolt. I have plenty of thread, so im sure it can go further, but tight is near tight enuf. Is there another sleeve that shims in there?
