freddy3
- Messages
- 479
- Reaction score
- 120
- Points
- 43
There are other adjustments on your voltage regulator besides that screw. There is a core gap and a point gap that must be within the given spec for the unit to perform properly .....
Thanks, 5twins. Unfortunately, the regulator in the bike appears to be working properly (the readings I got match the specs in the troubleshooting procedure in the Yamaha service manual), so I have to presume it's gaps aren't too far off, if at all. However, I have a second (NOS) regulator and both gaps differed, slightly, from your diagram. So I corrected them.
Do you have anything additional for the OEM rectifier? That's the component that flunks the service manual troubleshooting tests. I just returned an OEM-style rectifier that was passing current in both directions and I've got another one here (photo above) that's supposedly NOS, but clearly isn't. Anyway, based on the readings, two of the diodes are slightly off and the third is open, which is why I went ahead and started putting together the diy version in the preceding post.
