Hey guys, new to the forums here. I'm having an issue with my 81 xs.
I just converted it to the xscharge pma, and installed the new advancer unit and pamco ignition.
I set the base timing at idle, but it doesnt seem like my advancer is doing anything. Once I have the advance rod tightened on both ends, should I be able to turn a wrench on the advance rod and get the advancer arms to open?
Has anybody else had this problem?
The installation instructions were pretty vague on bushing and pin placement with the advance assembly. As of now, I have 2 brass bushings on the advance side of the rod,1 on ignition side, and 1 pin placed on the advance side to lock the plate in place with the cam.
Kit came with 3 dowel pins, and I couldnt seem to find a place for the other 2 to go.
Thanks in advance....
no pun intended.
no pun intended.
