Lost On Row 1
RacerX
The 12 volts on the burnt wire is why it is burnt. Remove and toss. 12 volts to coil terminal and wire advancer and pamco from there. The advancer and pickup are powered from the coil. The black wire from pamco should ground to motor and not connected to coil.
Do you mean remove the wire sticking out of the coil that the solder melted off? It is the one showing 12 v.
The rest of the wiring is as stated.
I did get a few sparks then nothing.
