For Sale - 1975 xs650 head - 35 Shipped
taggat
Anderson, IN.
Comes complete with worn out valves.
No broken fins, threads are all good.
35 Shipped
A little more for Cali or International.
You might have a hard time selling just the head alone. The head and the rocker box / cam cover that goes on top of the head are machined as a matched set and are generally not interchangeable with another set. If you have the cover and include that part , it would be more usable for someone.
Good luck!
We are talking about the 70's right?
Your right to a degree, they where machined together, some parts might not line up exactly from one match line to the next. I've never quite believed this unless its the transmission cases. Thats where things get wierd, lots of things connect and mate together. As far as the top end you can make that work swapping parts. In this case the only two critical areas are at the two cam bearing locations.
If your building a restoration bike for a keep it 100% by all means you probably wouldnt want to use this mismatch part because it upsets you deeply inside for some weird reason.
If your building some bike out of a pile of parts.... by all means, build it.
