For Sale - 1981 XS650 Special in Chicago
Paddy399
Still Lots To Learn
Chicago
1981 XS650 Special in Chicago (SOLD)
For Sale: 1981 Yamaha XS650 Special II
I bought this bike last year with the hopes of making it a project bike. I rode it around stock last summer and planned on doing the work over the winter. Due to some health issues, I wasn't able to put in the time and now I think it might be time for me to move on. I did start working on it so in it's current state it won't start BUT it won't take much to get it running again. The air box and side covers have been removed but will be included in the sale. I planned to put pod filters on so, as of now, the carbs are off of the bike. All that is needed to make this run is to clean and jet the carbs. All extra parts that I have, including a manual, go with the bike. The charging system on the bike works, I repaired that last year and has good compression in both cylinders. The bars and mufflers were installed by the PO. The bike has a clean Illinois title in my name.
O.D.O. 22,842 (Speedo and odometer do not work because the bike did not have a speedo cable on it when I bought it. There is a new cable included with the sale)
Included parts:
-Bought from Mike's XS-
Haynes manual
3 x Clutch Pushrod Oil Seal (01-9019)
2 x 57mm. Tapered Oval Pod Air Filter (2 1/4") (15-0027)
1 x OEM type Oil Filter Strainer (Sump) (15-6500)
3 x Gasket - Tappet Cover (3 hole) (18-0673)
1 x Gasket - oil filter strainer (sump) plate (18-0858)
1 x Fuel Filter - clear square type (20-0013)
1 x #135.0 Main Jet (Pr.) Lg. Round type (48-0119)
1 x #137.5 Main Jet (Pr.) Lg. Round type (48-0120)
1 x #45.0 Pilot Jet - (Pr.) - BS30/96 (48-0607)
2 x Carburetor Rebuild Kit 80-84 XS650's (48-1408)
1 x Tach Drive Block-off Cap (51-6514)
1 x Copper Drain Plug Gaskets - (Pk./ 2) (17-3802)
4 x Gasket - Tappet Cover (4 hole) (18-0672)
1 x NGK Plug Cap - LB05FP 5k Resistor (23-3113)
1 x Speedometer Cable (Black) 74-84 650's (51-3302)
-Bought from 650 Central-
650 Central Premium BS34 Jet Kit
2 Titanium slide needles with clips
2 Mikuni pilot jets
4 Mikuni main jets (2 sizes)
1 Drill bit for slide dampening modification
Instructions for tuning with various Exhaust & Carb/Intake setups
$1,650 O.B.O.
Any questions, feel free to PM me. Thanks, Pat.
