grease seal or not?
dspring
XS650 New Member
im replacing the neck bearings on my 73 with tapered ones from mikes. do i have to use a grease seal or not?
If you want the bearing to last, yes a grease seal is a good idea.
It keeps the grease in and the water out.
im concerned with the clearance from bottom of neck to top ef lower yoke. will it cause problems?
