xs650newb
Hey everyone,
I've been asking tons of questions on the forum lately and I thought it better to start a build thread to keep everything together. Also, this way I force myself to post tons of pictures.
Anyways, I've had the bike over 1 year and when I first got it this is what it looked like:
I bought it for 650 dollars and it didn't run. After cleaning carbs, changing spark plugs, and getting a battery it ran well. I eventually cut off the exhaust since it had holes in the mufflers, added pod filters, and finally rejetted. I also added drag bars, a XS750 tank, and custom seat.
The bike needs a new cam chain guide because there are black plastic bits in the oil and it is leaking oil from the head gasket, base gasket, and clutch pushrod seal.
Before I started my current top-end rebuild the bike looked like this:
I started my top end rebuild a couple of days ago and the motor is already out of the frame and disassembled. I just got the top end parts back from a thorough bead blasting. Also, while it was there I had the mechanic hone the cylinders, lap the valves, and replace the valve guide seals.
Here are some pictures of the engine parts after cleaning.
The mechanic has assured me that he removed all sand media from the heads before he reassembled everything. He suggested I go through the rockerbox and do likewise (since he didn't disasssemble and reassemble it) and I found a lot of sand. I have one up close shot here
