Just got my xs650 running,amd gave a peanut tank fir it, bur it has 3 outlets for some reason, anyone know if I can just plug the other 2, I only need the 1 small on
Yep - should be 3/8" NPT (or 1/4") threads on the bungs. Use brass plug found at better hardware stores with fuel resistant thread sealer. rear bungs are cool, but may be awkward, depending on you build. You can remove existing outlets and install
Yep - should be 3/8" NPT (or 1/4") threads on the bungs. Use brass plug found at better hardware stores with fuel resistant thread sealer. rear bungs are cool, but may be awkward, depending on you build. You can remove existing outlets and install View attachment 219532
