Punkskalar
Hugh's HandBuilt
Thats right folks, this bike is for sale. This time, without the engine. I'm planning to pull the engine and put it in another chopper unless someone wants to pony up the extra cash for it...
So what do you get? Everything you see here, MINUS the engine/Carbs
1980 Titled XS650
Custom Hardtail
Custom Neck Gussets
Custom Seat
Biltwell Seat Hinge
2" Barrel Springs
NEW Axles
NEW Forks Tubes
Rebuilt, Shaved 35mm Forks
Rebuilt Front Caliper
NEW Brake Line and Master Cylinder
NEW Nickel Plated Chain
NEW Stainless Buchanans Spokes on front Wheel
Akront 21" Front Rim (polished) laced to modified XS650 Hub
NEW Wheel Bearings and Seals
NEW Timken Tapered Steering Bearings
Shaved and Polished Upper Triple Tree
Shaved and Modded Lower Triple Tree
1957 Famous James Gas Tank, Redcoated with dual petcocks and custom gas cap
NEW Paint on Tins
Modified Front Fender to fit rear
CHROMED Handlebars, Fender Struts, Controls
18" Akront Rear (not OEM XS650, the REAL deal Akront) laced to XS650 Hub
Drilled and Polished Rear Brake Backing Plate
Chromed Brake Actuator and Linkage
Battery Box
Custom Aluminum HandGrips
REAL Avon Tires, not chinese copies
520 Rear Sprocket (32T)
ALL NEW Stainless Hardware throughout
ALL Powdercoated Black parts
Jockey Shift Linkage / Shifter (can be converted to handshift Easily)
Custom Drilled and Lightened Front Rotor
Custom Tail Light Mount/ Tag mount
Custom Exhaust included with the chassis
Custom Sleek Kickstand
BSA Throttle (Real, not a chinese copy)
REAL Bates Headlight (some minor welding done to reinforce tabs)
NEW Axle Adjuster, Powdercoated
Literally toss your engine into this thing and go have a blast...
$3500, ready to ship to you via Fastenal 3rd Party Freight for roughly $200 in the US.
email Hughshandbuilt@gmail.com
Hugh
1980 Titled XS650
Custom Hardtail
Custom Neck Gussets
Custom Seat
Biltwell Seat Hinge
2" Barrel Springs
NEW Axles
NEW Forks Tubes
NEW Paint on Tins
Battery Box
Hugh
