mconigliaro
Hey guys. A while back, I noticed that my headlight would turn off whenever I straightened my handlebars. When I turned them all the way to the right or the left, my headlight would come back on again. I figured I must have a loose connection somewhere, so I pulled the headlight out of the assembly, but I couldn't find anything loose inside. So I put it all back together, but then the headlight wouldn't come on at all anymore.
Next I started testing things with my multimeter. I seem to be getting good connectivity from all of the fuses. The headlight itself also *seems* OK (neither of the headlight filaments look burned out, and the multimeter shows connectivity between the terminals). I tested my battery without the bike running, and I'm getting just under 12v (11.4v or so), so I don't think that's the problem.
I've been using a variety of wiring diagrams to try to narrow down the problem. This one seems pretty good:
http://cyclepsycho.com/yamachopper/wires/81XS650_wiring_(fixed).jpg
I now believe I've tracked it down to that main yellow wire that plugs directly into the headlight. I'm not getting anything close to the 12v I assume I'm supposed to be getting (since the headlight says 12v on it). I tried measuring it with the bike running, and I get the same reading (something very low like 0.04v, but definitely not zero).
If you follow that yellow wire back from the headlight, you can see that it also feeds the high beam warning light (which also happens to not be working for me, though to be honest, I don't remember if it ever worked before). If you keep following this wire to the right on the diagram, it looks like it comes from the "reserve battery unit." According to a google search, this thing is supposed to keep the headlight from turning on until the engine is running, but that makes me think I don't have one. I know for sure that my headlight used to turn on whether the bike was running or not.
So now I'm a little lost on what to check next. Any tips? Does it sound like I'm on the right track? Just to summarize, the only lights that aren't working are my headlight and my high beam warning light. Everything else seems fine.
