1. Dismiss Notice
    Dismiss Notice
“Garage built, shed built”... stable built!
Discussion in 'The Garage' started by Bewarethemoon, Aug 14, 2019.
  1. Bewarethemoon
    Bewarethemoon XS650 Addict XS650.com Supporter
    I’ve had quite a productive evening tonight. Got the other leg that was causing me grief apart.
    My hex socket was 10mm too short to reach the lower damper rod bolt. I sacrificed a 10mm ball-end Allen key to make this. The box section didn’t locate easily inside the stanchion, every time I put a spanner to it, it seems to dislocate so I drilled a hole through so a screwdriver could be used in stead of a heavier wrench.
    This leg was more of a mess than it’s partner, there’s sludge I can’t shift easily so I’ll be making 5twins recommendation for a swabbing rod.
    When I removed the clip that holds the seal in place it broke apart as it was badly corroded, it’s left a path of destruction inside the fork leg.
    How should I best attack this? A small nylon or brass brush on my Dremel?
    I also spent an hour on the other leg with a blue compound and loose G quality mop
    Mailman, Raymondo and Jim like this.
  2. Jim
    Yes, that's how I'd go after it... the brass ones. I'd also consider a little sealant around the outside of the new seal to make it oil tight.
    Lookin' good. :D
    Mailman, Raymondo and Bewarethemoon like this.
  3. Bewarethemoon
    Mine is 1/2hp, I’m tempted to try 8”, at least 6”
    Jim likes this.
  4. Jim
    Go for the 8". You're runnin' more power than me and I run the 8's just fine.
    Bewarethemoon likes this.
  5. Bewarethemoon
    Jim likes this.
  6. Jim
    A non-hardening engine sealer. I'm partial to Permatex Aviation sealant... but whatever sealant you prefer. Just make sure it's the non-hardening variety.
  7. 5twins
    19,260
    10,494
    813
    My 8" is 3/4 HP and plenty powerful enough. My 6" doesn't have the HP marked on it but it's obviously much less because of the way you can slow it down if you push too hard. The web site claims it's 1/2 HP but I have to wonder about that.
    https://www.harborfreight.com/6-in-buffer-61557.html
  8. Bewarethemoon
    Anybody have any experience or insight into taking my pre-load adjuster assembly apart, I’d like to have the blue components re-anodised and thought it wise to ask before I delve in.
  9. Bewarethemoon
    Ordered some 8”s
    Jim likes this.
  10. Bewarethemoon
    Jim likes this.
  11. Jim
    Yeah, that's the stuff I use.
  12. Bewarethemoon
    Ordered some of that too
    Jim likes this.
  13. Bewarethemoon
    One leg all done polishing, I think I’m happy with the results?
    The 8” mops I ordered arrived over the weekend. So much easier! Cheers Jim!
  14. Bewarethemoon
    Also took the compression adjusters apart for re-anodising.
    Mailman, Team Junk, Jim and 1 other person like this.
  15. Bewarethemoon
    Cleaned up the corrosion with a brass brush in my Dremel.
    Onto polishing next.
  16. Bewarethemoon
    Anybody have any tips for cleaning up the stanchions???
    Jim likes this.
  17. Jim
    If you're talking rust on 'em... I'm partial to Brillo or SOS pads. They work great on any chrome.
  18. Bewarethemoon
    They’re in pretty good nick, a couple small blemishes of rust on just the one
  19. Bewarethemoon
    Replacement parts for rebuilding my forks arrived. It’s so obvious I’m in deep when I’m genuinely excited to open up the package containing them!
    I still need to take measurements of the o-rings and copper crush washer and order them. Any suggestions on where to buy good quality?
    I also need fork oil, the manual recommends Yamaha Fork and Suspension Oil 01 when I search for it this is the first hit https://www.motorcyclepartswarehous...MI6NKIgfOf6QIVFODtCh2ifATVEAQYASABEgJY5vD_BwE
    Is this the stuff?
  20. Bewarethemoon
    One final photo of my lower after a clean with Vienna Lime and then a good coat of Turtlewax. Feels good to have it waxed and put to bed for a little while!
Share This Page
