Wow Kop.
I've read your post many times now, and I'm really unsure how to respond.
I suppose I started the pissing contest by shouting 1180, which still remains to be proved, or disproved.
I totally get what you say about decreased revs available to a bigger motor, and I understand that my exhaust valves are bigger than standard (no one on this forum found it necessary to answer my simple question about that), but I rode the bike into the shop where the rebuild is taking place.
I don't think I have any problem with valves hitting each other, but there is definitely scarring where a valve has been touching a piston.
The cam I have is apparently not standard, with lobes that appear to allow for quick closing.
At this stage my technical ability is being stretched.
Please explain 'bleeding off cranking compression'
I was under the impression that all compression was a good thing ( while running anyway ).
As regarding the pissing contest, I think I started this whole thread badly.
I should have let the learned gentlemen here do the math for me.
What is clear is the bore.
87.5 xt500 pistons.
Stroke has been measured but by myself with a tape measure with the barrels and pistons removed. Just wobbly conrods, and I think that's where I made a booboo.
As you may have seen in my pics, there is certainly a stroked crank in there somewhere
Just not gonna commit myself to exactly what it is until the barrels go back on, which is taking a lot more time than first thought.
What interests me(amongst many things) in your post, is about the clearance volume and chamber volume.
How are engines measured for pissing purposes?
Is standard a 653 swept volume? Or does that include all of the above?
Does the intake valve not open at bdc?
As regarding cures..
We intend putting a thin gasket each side of the spacer plate, and I naively put decompression buttons into the head(according to some)
The Probe ignition will certainly help with spark timing.
Can't disagree with any of your cures, but I'm not ready to get someone to cut me a new cam just yet.
A long hard look at the electric leg sounds interesting.
Where would one start?
Thank you, Kop, for your informed input
