That's what I figured. I'll give you an idea. My pipes are similar to yours. I made brackets on the inside that go to the rear engine mounts.You can't even see them, but they're under the air filters, going to the inside of the pipe.
Hi Kent, Glad you like the pipes For others reading this Kent and I discussed mounting options and one of them was just like yours Tech Also I left the ends strait cut for Kent but can do slash up or down or even turnouts for anyone who wants it. Kent was thinking of putting brass tips on these when we started talking about making this set of pipes, are you still thinking of doing that?
I'm agree with your wife on the pipes. The pipes will look great just as they are. I'm anxious to see where you mount your rear master cylinder. Is the frame already drilled to accept it? jefft
Not yet, but there will be. I'm still weighing out a few ideas on that.
Kent
Thats the same pipes I have on my xs. For mounting them bought some pipe hangers I think they were called. It's like a hose clamp but has a rubber boot over it and a tab that hangs down. You can clamp these around the frame near the end of the exhaust pipe and use the tab to bolt to the piece that GS sent you with the pipes. It's a very nice clean way to mount them.
yeah...maybe i am just tired of looking at them, the two colors do nothing for me....i did the pipes a while ago and now i see more of them around...they sound really loud... a local guy made them up for $250.... i'll try the paint soon...
Kent
That was my initial thought as well, but on this frame, the exhaust ends up with some distance between the rear frame tubes. It kinda breaks up the curve of the pipe, and I'm not really digging that. I'll probably put a mount nearer to the center of the bike, running either off an engine cover bolt, or to the rear engine mount.
Kent
Why are you using baffles? No way I would do that. These pipes have the best sound of any xs I have ever heard. Don't mess with perfection unless the missis is tring to quiet it way down.
I dont have any mounts, they rest right on the side covers....never had a issues.
