Not mine but it's been through my shop recently! Thoroughly gone through.
Oil, both filters, carbs, petcocks overhauled By the Ole GG. New float valves AND throttle shaft seals! needles shimmed probably up one or two on the mains, pilots, New rear tire, XS1100 front rotor 650 central pads 10mm MC stainless steel front line. Charging system perfect with new rotor. I think this got tapered steering bearings, maybe brass swing arm bushings. EBC clutch springs, plates are good but clutch may need a little more help yet. Great compression, head retorqued, GG valve cover o-rings, cam chain and valves set. Stock TCI ignition works great Everything works down to the self canceling turnsignals. much chrome from a 83 swapped on. Fork seals, dust boots, fork oil done? Sportster mufflers, OK chrome a bit loud. I bought this as a project and put a lot of time and parts into it then traded it to Blue moon for paint work. Not perfect cosmetic condition but quite rideable as is and would be a great base for a custom or resto mod. clean title.
Bluemoon customs Oshkosh is the owner.
This bike is kind of a lesson, I am trying much harder to keep a page of what's been done for each bike I work on. The ole memory sucks after 20 or 30 xs's through the shop!
It also sucks that after all that work, it's sitting for sale at $800!!!!
http://milwaukee.craigslist.org/mcy/5262524677.html
The best deal going on the midwest CL You know, I'm tempted to buy it back.... I rode this about 100 miles a month ago.
