scum1
- Messages
- 8
- Reaction score
- 0
- Points
- 1
Hey guys just want to double check some wiring on an 80+ stator that is switching front he stock combined reg/rec, to the separate chrysler/radioshack version.
I did this mod years ago on my bike and I'm just fixing a few things and making sure i have everything hooked back up right. I noticed two different diagrams one for an 81' with combined reg/rec and one for an undisclosed year using separate. Will I be copying the original diagram but just use separate components. For example I believe the wiring should be
from the regulator-->grounded body to good ground, green wire to green outer brush on stator, brown to brown inner brush on stator AND to a 12v+ fused source. similar to the combined diagram below but only separate.
the diagram of the separate components has a brush grounded, but i think my regulator sends out the pulsed ground to the excited brushes??
I've been staring at the diagrams and playing with my multimeter and I'm just trying to understand how it should WORK just so i get it.
power goes from the fuse box -----to the inner brush via brown wire----throught the stator----back out the outer brush----to the regulator via the green wire---and regulates power back to the brown wire via pulsed grounding???
the quicker i understand how it works the quicker i can see whats going on..
thanks in advance guys
