Finally...a lot of measuring and machining,but now is every part ready and hopefully will it work also!
Use Alto 2,5mm plates,and steel plates machined down to 1,25mm,and some machining at the hub and pressureplate to make some room for the increased thickness.
And wanted to get rid of the pushrod and "whimpy" mechanism,so I took a mechanism from a Suzuki GT750 twostroke and modified the clutch cover to have the release mechanism on that.
As mentioned,much measuring,machining,measuring,machinig and so on...but hopefully a good gripping clutch without mega-hard springs!
And maybe overkill….but I like to test things and loves to work at the lathe and mill,better than a theraphysession at some doctor after a crazy day at work!!
Anders.
Anders.
