I have done a bit more research on coolers. The One Mike's sells for $85 is 4.25 inches by 6 inches or about 25.5 square inches. This is about the same as mine. should drop oil temps around 45-50 degrees.
I have looked on Ebay for other options. I found one from Briggs & Stratton, I'll show pics, Has a 4x4 inch core for 16 square inches. $29 plus shipping.
Found another that comes in several colors, pics coming, it's 3by 5.375, at 16 square inches. $27 with free shipping.
I think both of these would be better than Mike's, price is a biggie, but the smaller size should work out very well.
The Briggs cooler has hose barbs, makes easy plumbing. The other has banjo bolts. Will need to come up with hose barbs to fit. No real problem.
Just a guesstimate here but the 25 sq/in cooler gives 50 degree drop, so 50 divided by 25 is 2 degrees per sq/in. So the 16 sq/in coolers should give about 32 degrees of drop.
I think that is about ideal.
It looks like the Briggs cooler uses 3/8 in hoses, plenty of oil flow. The other one looks nicer, all alloy body but not sure of the size of oil passage. It may not flow enough oil to properly lube the engine.
I think i'll get one of the Briggs coolers and experiment.
The pic #2 is the Briggs. Looks to be very similar in design to Mike's just smaller. A very good design, oil flows into one end, through all the sections and out the other side. this design cools better than the Ford cooler I posted earlier. That style oil flows through a tube and the fins draw the heat away. works ok but won't cool quite as much.
The pic #1 is the other style I found. From other sellers it can be gotten in a kit with lines and mounts for $19.99 plus $19.99 shipping.
