So, I've taken off the LH cover. Dirty inside, now cleaned. Clutch mechanism looks and works okej. The worm gear is drawn back by the spring without any friction. But when the worm gear is in the bottom, there is a lot of free play. Correct must be no free play when worm gear is in bottom, right? If I correct it this way, the lever adjusting screw will be screwed almost out and the lever will be hard to pull as before. I have a feeling that the wire is to long. But maybe it's better to wait until spring and check this.
Before remounting the LH cover...
Should I dismantle the worm gear and put grease, or is it okej as is. Now it just feels like there is none. And should I put grease around the whole, now cleaned, clutch mechanism? Nothing mentioned in Clymer though about this.
