Don’t know if you got this but battery charging at 13.58v
Got the message charging voltage looks right if it is with lights on and a little higher rev-
The gentlemen who knows this year model are coming with suggestions
To sum it up
Ignition appears --- emphasizing appears to be right new parts and the same coils.
Charging are giving the right voltage. --.appears emphasizing appears to be right
Lower rpm makes the fuse hold at little longer.
I shall look at the schematic see if I can figure something out. Later tonight.
But more fuses would be way forward I have 4 on my 1980
Ignition / Signal / Headlights / Main.
Depending on the Circuit there can be a Possibility to draw own wires from Battery to function and from function to minus on battery.
Bypassing the harness entirely .In a stage of fault finding.
I am still at the charging circuit and it would be there I inserted the first extra fuse.
By the way a stupid question of Course since i Always had Crap Bikes always kick starting by the Schematic there are a Starter motor with relays and stuff.
That starter motor has a direct line from battery. --- Is it connected and Used and not have any strange behavior. Working as intended and starting the bike
Which would be a first. I ever I heard of that.
?? Disconnect and Kick start ?
