DirtyErnie
Renaissance Hick
So, after a freeway run from Minneapolis to Fargo and back last summer, it got pretty obvious my bike needs an oil cooler. The overdrive 5th gear and 17/32 sprocket combo puts more load in the transmission, which puts more heat into the oil, which doesn't go anywhere at 70mph. Nasty traffic backups weren't helping much, either. My first tank of gas got me 47mpg, which is about right. My last tank of gas on that trip was down in the low 30's. That's no bueno. Shifting was notchy and all that 'my oil is dead' kind of stuff was happening.
SO, since I have to pull the thing down and do head/base gaskets, might as well pipe in an oil cooler. But, if we're going to pump the oil outside the engine, why not add a remote oil thermostat, and maybe a filter also?
So, priority: 1. Cooler 2. thermostat 3. filter.
Fairly certain I can mount a flat-pack style thermostat without it looking all kinds of horrible. One like this: http://www.summitracing.com/parts/prm-1060/overview/
could fit on the right side of the engine, below and in front of the cylinders, or maybe completely hidden in the front bracket with a cooler mounted below.
Let's call this 'Number One' configuration. Shouldn't be terrible to implement.
For 'Number Two' (Who does Number Two work for?) How about we add a remote spin-on oil filter?
I'm thinking this: http://www.jegs.com/i/Derale/259/13005/10002/-1
plus this: http://www.jegs.com/i/JEGS-Performance-Products/555/51712/10002/-1?parentProductId=1032937
with a spin-on below. but where to mount such a beast without it looking like a tumor?
I took a few pictures of one possible location, with an R-134 can as a stand-in.
Thoughts from the forum?
