Brembo M/C brake light switch to yamaha wiring
Royboy
many roads, little time
North Central MN / Gold Canyon AZ (seasonal tramp)
I'm converting the front master cylinder on my 78'
Special to a Brembo unit from 650 Central. I've unplugged
the switch harness from the stock m/c but don't see how to
separate the harness from the stock switch without damage.
Since the new Brembo was supplied with a switch installed
but no harness I am assuming the intent was to use the old one.
After not finding a thread addressing this issue I suspect the
answer is so simple that embarrasment is headed my way.
Won't be the first time!
Someone please shine a light on this for me.:banghead:
roy
Just cut the wires and buy the correct size, as in very small, female spade terminals to plug into the brembo switch. The oem connector will not work on the brembo switch. I actually used some GM weather pac terminals I had. I put heat shrinks on each one, and plugged them into the switch. Covered it with corrugated loom
