Apparently there's some variances' in the springs used. There's no bent/hook end on either of these springs.You have both springs reversed. The bent end should face out and hook into the linkage bracket or cable arm .....
That's the way I'm showing 'em in my pics... short bent end facing out. Are you trying to say something else or are we on the same page?The BS34s don't, only having a long straight and short bent end. The short bent end goes out and hooks into the bracket.
Bul, don't forget that the seals go in with the open "cupped" side facing out.
Inside the carb is vacuum/low pressure. That sucks the edges of the cup tight against shaft and body.Really??!!! I'd certainly have gotten that wrong without your help. My brain is trained that the solid side always goes out.
That’s why I keep this stuff.A little grease on the seals doesn't hurt anything either.... petroleum based grease.
