I finally got all my carb parts and put it all together. Damn, those little balls and springs for the choke rod nearly drove me off the deep end. Found an earlier thread about getting them from zerk (grease) fittings. By the time I got both balls & springs in I'd lost 6 of the little balls. Some simply disappeared right in front of my eyes and 1 shot across my garage and I heard it hit somewhere probably about 15 feet away. I found that if I know exactly where the ball is I can see it. If not, I'll probably never find it.
I set float levels to 26mm, then did the bench test and both carbs level settled at or right below the spot where the gasket sits, which seems to be right. However, when I mounted the carbs on the bike gas started coming out of the right carb. Not right away, but maybe a minute or 2 later. I pulled the carbs back off the bike and did another bench test. This time it maybe took 3 minutes but then gas started coming out of the right carb.
I checked to see if maybe the float could be hanging up and it seems fine. Float is fine with no leaks. Then I set it up like doing the bench test but with the right float bowl off. Then I pushed lightly to close the needle as I poured gas into the carb to make sure there's no leak when the float is up. No leak.
So, any ideas? Only thing I can think of is that maybe I picked up the wrong float needle when putting it together but I think even that wouldn't explain why it would sit at the proper level for a while and then flood.
