billy icon
test pilot,gunnie pig, and all around experiment
lol had to catch up there with the likes
I will let you know if that works and thanks for the advice and pictures those will help me out too.Yes, that might work, depending on how hard the rocker is. Try it and see. If it works, it may be easier and not as messy (dirty) as grinding them out.
and again im just going with the armchair observation of the photo I have to look at, but it seems there is a gap or space between the elephants foot and the first thread where its machined down.. and there are no threads there, but the ones i was showing look to have threads right up to the head, and possibly BIG on the possibly have a shorter dimension from the flat spot of the ball to the back of the head, and so maybe less that 4mm of thread would need removed, ya know?
yes im quoting myself here, I have under closer examination relised there is not thread up to the back of the head on the ones I showed here, and i now do not think these will be appropriate for our uses, that being said I am still ordering 8 just to see for myself what's what.
I still want kedos
I would have removed the rockers if I was going to just grind it flat, but I feel the taper may be better since you cut off less material.Its clearly not necessary, but would it have been easier to remove the rocker? It's not that much work to remove them.
I am sure the stronger the rocker the better. I did buy the shell cam off a guy who did a 270 degree setup. I have the Kibblewhite springs installed I bought them off eBay from hoosracing. Hoosracing also does the shell regrind. https://www.ebay.com/itm/283749623756look really good bushyeyed1 ,i got some more parts for my build today, just waiting for the machine shop to call with my cly. I installed my 5th well ..I don't want to highjack, it will all be in my thread. I really like the look of the rocker arm when it is NOT ground flat, still looks like it has a lot of strength, I would asume its more important when using stiffer valve springs, speaking of that, did you buy that "shell"cam and what springs are you going to use?
