So I need to replace the 2 cam bearings on the left side of the engine. There is definite "play" in them. I believe this is why I have had frequent leaks from there, even after I replace the seal on that side, and more top end noise than normal. There is no movement at all on the right side and I have never had a leak on the right either. I realize that conventional wisdom would say if you have to replace one, you should replace them all, but at $17.00 each, they are not cheap. Just wondered what anyone else thought. One more question. Dip in oil, or pack with grease?
Thanks
Thanks
