Travis, detuning the engine by dropping compression isn't something I advocate, but John's approach was to double up head gaskets. The more usual approach is to use a base plate; Cometic can make a .040" copper base gasket for a reasonable price, and installing one under an OEM base gasket will yield approximately 8:1 static CR on a stock displacement engine. Seal at top, middle, and bottom with Permatex Ultra Gray or Ultra Copper. Raising the deck will advance valve timing, so you'd need to degree the cam and move the sprocket as well. My personal take on this operation is that someone who wants an engine that will lug like a tractor is better off with a Hardly Ableson. Lugging an XS650 engine is every bit as destructive to it as ignoring redline.
