Since you started this thread 4 days ago, with the title "Choke not working", everyone has focused on the choke. It just appears the choke is not working, your real problem is the pilot circuit is not supplying enough fuel/air mixture. Its obvious when you need the choke circuit to supply extra fuel, to keep the rpms up, because the pilot circuit is plugged.
A couple of days ago it was suggested to remove and clean the pilot and main jets. Now today, you say you have not removed the pilot jets. When the engine won't respond to the throttle, the pilot jet/circuit is the first thing that should be inspected.
Take both pilot jets out and see if they are plugged up with crap, as I'm sure you will see that they are.
