nobackhair
Replaced w/ new Ferrodo disc w/ stiffer springs 14% increase, and new HD clutch cable from 650 Central. Used Diesel motor oil in case. It's not releasing gradually. Soon as it has any contact it grabs and makes full contact and lundges. So it's very jerky obviously. Makes a dull squeeling sound. Have it apart. But I can't see anything wrong or was anything loose. Yes I has the little dot matched up and my plates were flat. Both ball bearing are in. I can't imagine it being the oil. Maybe adjustment. I have it making connection about a 1/2" out on lever.It's fine after I'm moving thru gears No slippage no noise. There wasn't any debri in oil. I've gone thru the sequence of location of washers, etc. When one pulls lever all the way in it moves about 3/16 to a 1/4" at most and not all disc show any movemen't.
