Rlauchard
Hi all,
I wanted to try a visual approach that bridges XSLeo's 'What happens when you turn your key on' and the wiring diagrams that I see all over the site. I also want to use this to build my wiring diagram.
One of my challenges is not understanding wiring fully, how things flow, etc. I wanted to start simple and as I hash the small things out verbally and visually. If you are willing to participate, it is appreciated. Hope that this will work out.
What I am wiring:
- headlight low/high
- front and rear turn signals
- speedo
- horn
- left control with lights, turn signals, horn
- right control with kill switch and electric start
- key
- pamco ignition
- oem alternator
- rectifier
- battery
- electric start
- tail light/brake light
- blade type fuses
- coil
The first step that I wanted to look at was wiring the following:
1. From the battery to the starter relay to the starter
2. From the battery to the rectifier to the key
3. From the key to the fuses, to the tail light
Here are my questions/callouts as I understand this stuff.
1. I am running a blade type fuse box...it has a 'power in post' as I like to call it...it is this. I believe with this, I need to run my key power to the 'power post', then run all power to the other items (which I will update later) from the fuse box.
2. With the above being said, I am assuming that I have to have an inline fuse of 20 amps in front of the key/rectifier coming directly off the battery.
3. I am assuming 6 gauge wires from the battery to the starter relay to the starter motor. I am assuming 16 gauge wires throughout the bike. Right now...what gauge wire should be used from the battery to the 20 amp inline fuse? Is that 16 as well?
4. I am putting a block arrow to show flow of current so that I can fully understand how things are working together.
So, for this round of community participation of wiring a bike, here are the outstanding questions:
1. Do I have this correct so far?
2. What gauge wire should I use from the battery to the 20 amp inline fuse?
What I am wiring:
- speedo
- horn
- key
- pamco ignition
- oem alternator
- rectifier
- battery
- electric start
- blade type fuses
- coil
