fullashit
Hi Everyone,
I know this has been discussed at great length here and I have spent the last week reading everything I could find online and on this site and I believe I have it nailed but don't want to buy another part without making sure.
I have an '80 xs650 special. I just this spring installed the mikes xs (xs direct here ) Basic pamco ignition/ charging kit with the pamco PMA. I've done about 6000Kms on this set up with no issues then after the bike started running crappy I checked my battery and was at 11.9v and not charging at any rpm. I replaced the battery and tested it for voltage drop overnight and with a load on another bike and it's good. I tested continuity on all the wires in the charging system and all was good. I tested the resistance of the stator and got readings of .4ohms across all 3 white wires which to my understanding is a touch low but I have a cheapo multimeter. SO I'm thinking it's the regulator but it doesn't look burnt around the wires at all. I checked all the wires around the stator and they all look good although it is all a dark copper colour and no longer has it's green highlights! I tried the slap test but it seems as though that the pma is isolated and that test doesn't work ????
Any insight would be appreciated. I am not with the bike until Friday so i wont be able to do ant tests until then just asking now so if I need parts I can get em!
Cheers!
Cheers!
