Run the adjuster nut up tight, then tighten the axle.torquing the rear axle whilst applying the rear brake
Cheeses Kay Riced, guys, you're not lifting a half ton of diesel motor, you're lifting an air cooled 2-banger that weighs less than160 lbs! Here's the drill I've followed for years, for what it's worth.
1. Strap bike down on lift. Remove all motor mounts. Insert one bolt in back of motor and one bolt in front. Put a loop of a tie down strap on each end of each bolt.
2. Throw a ratchet tie down over a rafter above each strap. That's right, kids--a cheapass ratchet tiedown with a nylon or poly strap--remember, each one is only going to lift 80 lbs. Attach a hook to each strap on the motor. Crank 'er up.
3. When the motor is a bit free, finesse it out of the frame, roll the lift with bike away, and scoot a table under the hanging motor Let the motor down and do the needful.Use wooden blocks, etc. to position and support the motor while you work: engine stands are for sissies.
I see the misunderstanding now--there's no way my 70 year old back would take it if I tried picking up that motor by heaving on a pair of straps! OK: Tool 1: Handlebar straps from tie down kit (nylon straps with a loop at each end). Tool 2: Poor boy's hoist--ratchet tie downs hooked onto Tool 1, lifting done with finger pressure. The bike is strapped down to the lift only to stabilize the chassis while the engine gets wiggled out.
Sure, I've removed/installed the motor by lifting/lowering the rolling chassis, but the slug still has to be lifted to and from the bench. Used to get that done by using a 2x6 board for a ramp and horsing the beast up.
My thought is to hang the cable winch from a rafter, pick up the frame with the engine off of the bike jack with the cable winch.
Then set all that down on the ground, lay it over sideways on some cardboard, unbolt the motor and lift the frame off. Then re attach the cable winch and lift the motor back up, set it on the dolly, so I can roll it around.
Does that sound like it would work?
Crazy seems like you could at least wipe the dirt off the motor if you're going to take pictures.
To be used to secure a load from moving, like a tie down on a trailer or the bed of a pickup truck. The load is "dead" in the sense that it does not move.By the way, what the heck does that ad mean when it says that 4000 pound winch is “ For dead loads only. Not lifting”. Huh?
