5twins, One of the rotors I have test fine at room temp but after running awhile and the temp goes up on the rotor the ohms goes up along with it. At full operating temps the ohms go up to around 8.5 and the voltage at the battery starts to drop off.
Basically the 5 ohms creates about a 2.5 amp current flow through the rotor which creates the proper magnetic field around the rotor. Change the resistance and the current flow changes. 4 ohms would be 3.1, 7 is 1.8. The higher the current the stronger the magnetic field. At what current flow does the magnetic field get too weak to charge? I'd say some where in the 7 to 8 ohm range.
I think most of what Custom Rewinds does you have about 4 ohms of resistance. This slightly less resistance gives a slightly higher current flow. This increases the magnetic field and in theory increases the output.
Increasing the ohms reduces the current so it should decrease the output. At some point the increase in ohms should decrease the output enough to not charge the battery. That's what was happening on my with the bad/high ohm rotor.
Some spec's call for 5 to 7 ohms. As long as there are few electrical draws on the system your 6 or 8 ohm rotor should work Ok. A lot of around town where the brakes and turns get used you might not charge the battery up as well. On rides out in the open where you won't ne using the turns and such as much then it should work fine.
I might suggest converting to LED bulbs on things like tail/brake lights and turn signals.
This will decrease the draw under all conditions and leave more power for charging.
Installing a volt meter on the bike so the rider can see what his charging system is doing is a good idea, on a system that works but is at the edge of the specs I think it's even more so.
That's how I noticed my rotor. When I first start out the voltage is fine Right up at 14+. After an hour or so I noticed the voltage was dropping off. At first it was about 14, then 13.75, 13.50. I said wtf. And headed home to do some checks. Let it cool off so it was more comfortable to check and found the ohms were fine. Eventually I rode it till things were getting low and checked, scorched the fingers a bit and found that when hot the ohms were high.
It one of the three in a stack by the computer. Just waiting for a trip to Custom rewinds.
